drsteve
Mar 29, 2018Explorer
Flarpswitch wrote:
The pump that came with our 2018 RV is a regular pump, but for whatever reason, the new design is so much better than in the past. I did have a surging episode when air got pulled into a hot water line to the shower. It caused not only the change in flow, but it made the tankless hot water heater crazy because it senses flow and then turns on.
Your new RV has a better pump because the manufacturer has no choice. A cheap, barely adequate pump will make your tankless WH really crazy.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
