Byrogie
Oct 12, 2016Explorer
Old-Biscuit wrote:ggadwa wrote:
It does have an accumulator tank. I think I'll check it and air up if needed. I sure would be a happy if the Pump is OK. It never runs when on and just sitting unused.
Gary
Oh so more to the story......
YOU turn pump off
Then when you open a faucet no water but use to be
That is because the accumulator isn't pressurized....if it was it would push water out an open faucet.
Pump not cycling when ON and no-demand..then pump is working and check valve is not leaking
Problem is at accumulator tank
This why it is important to have all the information.
Makes for a better diagnosis, and less guessing.....
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
