steve_ellyn's avatar
steve_ellyn
water pump location
Hi all
getting ready for spring maintenance. i have a 04' fleetwood revolution.
anyone know the location of the house water pump?
  • Go to the wet bay. On the left there is a small panel held on with four screws. Remove the panel and there's the lump as well as the latching relay.
  • Open the low point drains, turn on the pump and follow the sound :)
  • Old-Biscuit wrote:
    Water pumps are typically located very close to fresh water tank.
    Don't know what type of RV yours is.......TT, TH, 5'vr, MH etc.
    Turn it on (they can run dry with no problem) and then listen for the noise.
    Could be under a storage lid, inside a cabinet, behind a panel in storage compartment, in the 'wet bay', under the bed.......
    Is this a 'new' to you rig?
    yes new to me class a. 04' fleetwood revolution
  • Look behind panel in the water compartment.
    Turn it on and listen for it?
  • Water pumps are typically located very close to fresh water tank.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
