etrippe's avatar
etrippe
water pump maintenance
My water pump is making more noise than normal. I found the pump and need first to clean the screen. I have never done this before so I have a question. I did find the pump and it is installed lower than the water tanks so I was wondering if I need to drain the fresh water tanks before disconnecting the filter housing. I know to turn the pump off, remove any pressure and do not have city water hooked up. But what about my fresh water tanks? Can they have water in them and it won't drain once disconnected?
thanks in advance
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 15, 2026
