ajriding's avatar
ajriding
Explorer II
Jun 05, 2015
Water Pump Motor Repair
Hi. I have a Shurflo waterpump. It works, but is slow. I have taken apart the diaphragm and inspected it and it looks great. It seems the motor is running slower. The motor usually makes enough noise that I can hear it running, but now is so quiet I have to be near it to hear it running.
The water out of the shower head is just strong enough to look like a shower, but is very weak.
Is this the motor?
Can it be repaired? Can the motor only be replaced?
(I know the knee-jerk answer is to tell me to replace it. I have read enough forums to know I will get a lot of "replace it" answers no matter what the question or how expensive or cheap the item is, I know already about the option to replace something, I am not on a forum to figure that one out. I am looking for advice on a repair, thanks.)
  • I haven't seen this addressed yet, but are your batteries at least 12 volts? If your battery voltage is low then I believe that your pump is going to run slower.
  • As noted, the motors are nearly as expensive as the whole pump (a few are actually more!). However, you can certainly take the motor apart, oil the bearings and replace the brushes, *if* you can find replacements the right size.
  • YES you can replace motor.
    HERE are the part numbers for the 'classic series'
    But motor will cost roughly $60
    You can buy new complete pump/motor replacement (Shurflo 4008) for $65
  • Some pumps have a filter bowl between the fresh tank the the pump. If you have one it might be plugged. I would try to eliminate the water source or hose first, then disconnect the outlet hose at or near the pump and see if if is any different there.
  • I'm sure you don't need to put a line pressure valve downstream of the pump to confirm what you already know. Replace the pump. It's an easy install and they aren't expensive. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
