wa8yxm
May 25, 2021Explorer III
assuming you have water in the tank the pump may be sucking air.
But it does take a while to clear the lines of the air in them after draining.
Assuming you have given that time I'd check the inlet strainer on the pump. then inspect lines and and valves before the pump.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
