norrisboat
May 25, 2021Explorer
jdc1 wrote:
Let's start with why you replaced the first pump. What was it doing? The same thing? Then you have a vacuum leak....you are sucking air somewhere like CAtraveler says.
I replaced the pump because the original had a leak(gasket). Instead of getting a rebuild kit for it, i decided to get a new one.
If I was sucking air, wouldn't water come out of the leak? If there is a leak, wouldn't it be before the water pump?
Isn't the water tank non-pressurized at all times? Not sure and just wanted to confirm.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
