norrisboat
May 25, 2021Explorer
opnspaces wrote:
Are the inlet and outlet hoses reversed?
Plug the winterizing bypass hose that sucks antifreeze into the pump.
Disconnect the outlet from the pump and turn the pump on to see if water comes out.
I tried reversing the outlet and inlet. When I reverse them I get absolutely no water. If they are the correct way I get spitting water.
If I disconnect the outlet and turn on the pump I get nothing coming out when its in the correct configuration.
I have also reversed the wires to see if it produces a different result. No difference seen. Someone mentioned above that since its a diaphragm the wiring won't make a difference. Makes sense to me but I reversed the wires anyway with non difference in result.
Thanks for the help.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
