CA_Traveler
May 25, 2021Explorer III
norrisboat wrote:
If I was sucking air, wouldn't water come out of the leak? If there is a leak, wouldn't it be before the water pump? Yes The hose likely drained when you replaced the pump and hence may not leak. With a vacuum leak it can't prime and sucks air.
Isn't the water tank non-pressurized at all times? Not sure and just wanted to confirm. Yes
Again connect a new hose into a bucket of water. This is to help verify it's not a pump problem. Or remove the pump and bench check it.
You can also plug the overfill, pressurize the tank with compressed air and look for leaks but this is likely more involved.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
