wa8yxm
May 25, 2021Explorer III
norrisboat wrote:
If I was sucking air, wouldn't water come out of the leak? If there is a leak, wouldn't it be before the water pump? Yes The hose likely drained when you replaced the pump and hence may not leak. With a vacuum leak it can't prime and sucks air.
You would think that but a line or fitting can be water tight without being air tight.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
