otrfun's avatar
otrfun
Explorer II
Sep 21, 2013
Water Pump Output
I have a Shurflo 4008-101 water pump in my TT. It's rated at 3 gpm. It puts out decent pressure--like a lot of things you'd take more if given the choice. I realize the 3 gpm rating is probably with ideal voltage and flow rate measured right at the pump's output nozzle (and water source next to the input). Anyhow, I took the shower head off and did a quick test with both hot & cold both completely open. Got 1.5 gallons in one minute. About 1.25 with the shower head on. Just curious if anyone else has tested their water pump's realworld flow rate?
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 14, 2025
