RoyB
Jun 13, 2013Explorer III
There should not be any difference between using your generator and the shore power from a 120VAC Electrical receptacle source.
Does this same thing when you are hooked up to a regular shore power connection?
Perhaps the 60Hz waveform from the generator is not as good as it should be... What generator are you using...
You may have a couple of issues here...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
