Ron3rd
Mar 03, 2020Explorer III
markchengr wrote:
If the wires connect to your pump with those push onto a blade type connectors there may be a bad connection at that point due to corrosion. Try sliding the connector off and then back onto the blade several times also wet it with contact cleaner if available. I have had that problem and if that's what it is then it's an easy fix.
That's a very good point.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
