mich800 wrote:
dave17352 wrote:
Thanks for all the suggestions. It is definitely on the inlet side. I have no idea what happened but I have leak right at the top of the fresh water tank. I am thinking where the fresh water line enters the tank. I had two thirds of the tank filled and no water leak. When I filled it to the brim a little water leaked out. I checked the pump by running water through the winterizing hose and it worked fine so.... I replaced the pump for no reason. :( Works fine with city water inlet though.
So does it work now?
A leak there should not cause the problems you are experiencing. The tank does not need to be pressurized. You are drawing air somewhere in front of the pump or the pump itself.
Exactly^^^^^
Tank has a vent so a small crack/hole on top of tank would NOT affect pump being able to suck water from tank.
Air leak on suction line between tank and pump, strainer gasket, winterizing set up etc allowing air into pump ---hence no priming/pumping
