The water pump itself actually doesn't make much noise at all but due to inadequate installation is noticed as very noisy in operation because what little vibration the pump does make radiates out through the water lines connected to it and is amplified wherever these lines may contact the floor, walls, cabinet panels, etc. The key is to isolate both the pump itself and the lines, most particularly the output line. Shurflo's so-called pump "silencer kit" is actually quite ineffective as it consists of just two 3' long braided hoses but to effectively dampen pump vibration the output hose needs to be
much longer. 15' will do in most applications, I used 25' and my Shurflo Revlolution is now so quiet in operation I had to add a light to the pump circuit so I'd know when it's running. :B
Silent Water Pump Operation (pics & video).
