jodeb720 wrote:
As I'm here in Yosemite, my water pump has decided to not stop running when all the taps are closed.
If it's still pumping water (and you haven't said it isn't) I'd just leave it as is for now and deal with it when you get home, assuming you're not full timing. Just turn the pump switch on when you need it, otherwise leave it off. These are run dry pumps so you're not going to harm it in any way and surely it will be much easier to identify the true nature of the problem and correct it properly once you're home again. ;)
