Reisender
Jul 04, 2023Nomad
TheLostBoy wrote:Reisender wrote:TheLostBoy wrote:
Greetings all,
I've had two campers in my life and the first one I had was pretty rough and had lots of issues. One was that the water pump would randomly run for a second or so, which I didn't have the time or funds to look into, so I just turned off the pump at night so we could sleep.
We upgraded to a "newer" (to us) Jay Feather and for the last couple of years, we had no issues with it, but for our last two trips, the water pump started randomly running for a few seconds, just like our old camper. It SHOULD only run when water is called (faucet is opened) and I don't think I have any leaks (that I can see) and I made sure that all of the faucets were closed, but it STILL runs randomly and it it so frustrating. Do I need a new pump (or whatever the sensor is that tells the pump to run when the pressure after the pump drops)?
Thanks,
TLB
Good morning lost boy.
Start with replacing the check valve. If that doesn’t work you have a leak.
The other thing I would do is check to see that the taps for your outside shower are turned off good. People forget to turn those off and just rely on the sprayer stop.
Good luck with your search.
John.
Yeah, the outside shower was the first thing I thought of, but they're all tightly closed. No obvious leaking either.
Oh ok. Then give the check valve a check out.
I also had a pump diaphragm with a pinhole leak in an RV about 20 years ago. Tough to chase down but hang in there.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
