LouLawrence
Jul 04, 2023Explorer II
The accumulator (bladder) will not help solve your problem, it will only make the pump cycle less often but for a longer period of time while the accumulator gets re-pressurized.
It never hurts to have a spare pump so, assuming the pump is easily accessible, I would replace the pump first. There is an internal check valve in most so you would know pretty much right away if that's where the issue is.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
