IamSiler's avatar
IamSiler
Water pump runs continually
We purchased a used MH Sand are on our first trip with it. We are new to RVing as well. The water pump runs continuously. We watched a YouTube video about getting an open valve closed and went through the steps twice and it hasn’t helped.
Is there anything else we can check before we take it in to the repair shop?
  • The most common cause of this type problem is, you have your City Water tank fill valve OPEN. This will cause the pump to continually recycle the water. I also assume it will turn OFF when requested to do so? From the Pump On/Off switch?. Now, if you are connected to City Water and that valve is left open, your fresh tank will overflow. You are new to the forum. ALWAYS, list Year/Make/Model/Chassis of RV when posting. Or put this info in your profile. Doug
  • Only a few things will allow a water pump to run continuously - an empty fresh water tank, a bad check valve, or a leak.
    Do you have water in your fresh water tank?
    Are you hooked up to a water connection? And if so are you leaving your pump on?
    Are your valves set appropriately?
    Is there evidence of a leak somewhere?
    Was there any sort of pre-delivery inspection done on this MH?
    By the way, did you get your light switch sorted out?
Having RV issues? Connect with others who have been in your shoes.24,285 PostsLatest Activity: Jul 22, 2025
