DancinCampers
Jun 24, 2023Explorer II
If I understand correctly, this surging happens while you are using water, and not when the faucets are turned off. There should be a pressure adjustment allen screw on the pressure switch. Turning clockwise will increase the pressure at which the pump will turn off.
