Lectric80
Jun 24, 2023Explorer
QCMan wrote:
The answer is that you have a leak in your water system someplace at or after the pump. The pump is trying to build pressure but it can't because the pressure is leaking out someplace. Start ar the pump and make sure all fittings are tight and keep an eye open for wet spots.
No that would be cycling when I'm not using a faucet, that I'm aware of and all lines and systems have been leak checked.
