Lectric80
Jun 24, 2023Explorer
DancinCampers wrote:
If I understand correctly, this surging happens while you are using water, and not when the faucets are turned off. There should be a pressure adjustment allen screw on the pressure switch. Turning clockwise will increase the pressure at which the pump will turn off.
This is the info I was looking for, thank you I'll get into it and check it out.
