salem's avatar
salem
Water Pump Surge
We just spent five nights in a partial hook-up park. We used our own shower a few times instead of the public showers. Everything worked fine till the last night. When the shower was running the water pump sounded as though it was surging. I thought perhaps the tank was getting low, so I filled the tank but the problem persisted. Now, the bathroom sink faucet runs just fine as does the kitchen sick faucet. Normally, when using the pump there is just a steady purr. With the shower it goes louder, then softer. Water pressure seems to stay the same. Trailer is a Starwood 5th wheel, by McKenzie. Where should I start looking for the problem? Thanks.
  • Installed the new Oxygenics shower head this evening. Very simple to install. First impression is that we are going to like it very much. Puts out a good, powerful stream of water. Much more so than the old one. We have a trip scheduled in a couple of weeks so we'll give it a good workout. If you're curious, we got the #24682 brushed aluminum, $39.00 on Amazon.
  • Mr. Wizard: I removed the OEM (2005) shower nozzle and low and behold it purred like a new born kitten. Put the nozzle back on and the surging sound started up again. I've been putting off ordering a new Oxygenics shower head but I guess it's finally time.:) Thanks for your help.
  • If, perchance, you did run the pump when the tank was low, you may have gotten air in the lines someplace. If all faucets/shower are getting a good flow of water but the pump still gets loud, open/close the low point drains to get the air out of the system.
  • pump pressure is building
    try the normal outlet and the hose without the shower head
    might be time to clean or replace the shower head
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 01, 2025
