NewtekExplorerJun 30, 2020Water Pump Switch(s) Wiring guidanceHi, I just replaced my sensor panel & the wiring was a bit updated on the panel itself, however I need guidance on the water pump wiring as follows: Water pump switch in sensor panel & another in ...Show More
enblethenNomadJun 30, 2020See if this helps.Four switch diagramThis type different type of switches then just two wire.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentFleetwood Angler wiring2005 SixPac D850 WiringBad tail light wiringGuidance NeededFW 120v ac wiring guidance
