shadows4
Aug 23, 2022Nomad
OP'er here. I checked and no o-ring in the cap for the winterization port. I found one in my plumbing stash and installed it. I have the hose from the water tank disconnected and stuck into a bucket of water. The pump sucks the water out of the bucket just fine and the pump will build pressure and shut off just fine.
When I open the bathroom sink faucet it runs good for a few minutes then will start spitting again. It's not as bad as before the o-ring but it still spits. I have ordered a set of pex plumbing tools and will start replacing sections of the manifold. I am at a loss so that is my only recourse that I can see. Thanks to everyone who has responded. The encouragement is definitely a help.
Here is some pics of my water setup. All the fittings appear to be tight except one. It is behind that block of wood. I will replace the pipe and the clamps when my pex tools come in. Again thanks.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
