shadows4
Aug 25, 2022Nomad
SUCCESS!!!!
I did find the air leak. I went to the hardware store and bought a fitting to plug into the end of the hose from the water tank. I then attached my blow out plug that I use for winterizing and applied 20psi of air pressure. I'll be darned if the leak was where I thought it was. In the last pic above it was behind the little block of wood.
So all in all I have $70 in a new water pump (thought originally that was the problem), and $80 in pex tools and clamps. I think it would have cost me more than $150 if I had to take it to a dealer. Thanks for all the replies and suggestions. You all are awesome!! Thanks again.
This is how I hooked up the air from my little compressor.
The short red section of hose is where the leak was. That is the new piece in the picture.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
