Dick_B
Sep 07, 2015Explorer
This problem has been discussed previously. A few suggestions: 1. be sure all the valves are in the correct position to get water from the tank and not from the winterizing line. if there is a filter upstream be sure it is not clogged. 2. turn on the pump and open all the faucets for a couple of minutes 3. reverse the inlet valves and try to get some water into the winterizing line by holding it up vertically to put pressure on the pump inlet.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
