SoundGuy
Sep 07, 2015Explorer
Chris Bryant wrote:
A quick fix is to use a wet dry vacuum on a faucet to "pull" a prime. once primed, the pump may be fine.
Connected to a trailer's water system that's leak free any of these potable water pumps should easily prime without having to "pull" a prime. Since the question is whether or not the pump itself has an issue I'd disconnect it's intake and output lines from the trailer entirely and run a short hose directly from a jug of water directly to the pump intake. If the pump is functioning correctly it'll prime almost instantly, in which case you'd know there has to be a leak elsewhere in the camper that won't allow the pump to prime no matter how hard it tries.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
