This winter I winterized and pumped RV Antifreeze through the system. When we were getting ready for this trip. I flushed the system and put water in the tank. Now the pump runs but does not shut o...
Check if you closed the line that you drew the antifreeze with. If that is still open you will not be able to pick up prime. You need also to open the line from your FW tank to the pump
I've done it before and still need to double check myself
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
