wbwoodExplorerDec 26, 2016Water pumpThis year when I winterized the motorhome, I goofed and forgot that the water pump was on and hit the check valve on the city water inlet on the outside. Had to replace the city water inlet due to the...Show More
DutchmenSportExplorerDec 26, 2016Once you turn the pump on, you need to open one of the faucets so it will stat pumping the pink.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
