This year when I winterized the motorhome, I goofed and forgot that the water pump was on and hit the check valve on the city water inlet on the outside. Had to replace the city water inlet due to the...
I usually leave some water in the FW Tank prior to pumping pink stuff which maintains the prime. Then I drain the tank. If opening one faucet doesn't work try opening another one. I have a short hose connected to the pump inlet for pink stuff. As a last resort try pouring some pink stuff down the hose to prime the pump.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
