joe0508ExplorerOct 21, 2017water pumpI have a surflow water pump 40psi.I went to winterize it.I drained all the water from the water heater and bypassed it.I than drained the fresh water tank using the water pump and letting the water pu...Show More
mobeewanExplorerOct 21, 2017Make sure the fittings you added are tight and not sucking air. That will keep the pump from priming and antifreeze from being sucked from the jug.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
