joe0508
Oct 21, 2017Explorer
water pump
I have a surflow water pump 40psi.I went to winterize it.I drained all the water from the water heater and bypassed it.I than drained the fresh water tank using the water pump and letting the water pu...
Itinerant1 wrote:No.It doesnt have any valves at or near the pump or the tank.The only valves i have is on the back of the hotwater heater.I have the two that runs from the hotwater heater off and the middle one that connects the two on.I have done this before with no problem.This time i drained the tank using the pump but i didnt think i runned it dry because it was still flowing when i shut the pump off.the water stopped shortly after..Im pretty sure its a priming problem because it worked fine when i shut it off.I just wasnt sure how to self prime it.I think i got it.I think i need to feed the antifreeze directly with a turkey baster or something similar and than once it excepts it shut the pump off and put it in the antifreeze?I tryed to open faucets and toilet but not for very long.It will take me a while to get back to to try these things because it is in storage and i am over the road but i will have to get back to it soon before the weather gets bad.Thanks for all the replies as always.Great forum
Joe0508 hopefully you figured out the problem. When you added the connection to draw from the anti freeze jug did it have a pepcock to stop drawing from the fresh tank?
