joe0508
Oct 21, 2017Explorer
water pump
I have a surflow water pump 40psi.I went to winterize it.I drained all the water from the water heater and bypassed it.I than drained the fresh water tank using the water pump and letting the water pu...
grampscamper wrote:Yea.I think the length of pipe i have leading to the jug is a little long.I took the original pipe off and replaced it with one of my own.The pipe is 3 foot to the jug an elbow with another foot and half down in the jug.Im thinking maybe i need to bend that elbow up and fill it up with antifreeze and turn the pump on.. that might just get it to working again?
I had a trailer that gave me trouble in the past. I would have to close all taps then open only one for it to prime. Sometimes I would have to open and close it a couple of times. Keep the siphon hose as short as possible. Place the antifreeze jug close to the pump and make sure it isn’t getting sucked to the bottom of the jug. I cut my hose on an angle.
Good luck.
