I dewinterized my class C today. Hooked up to park water. Ran water through all outlets. Did not find any leaks. Disconnected from park water and tried pump. Pump would run but only spit water and air...
Did you open a valve while the pump runs? My pump often will not prime after sitting in storage unless I open a faucet. Otherwise may have a pipe issue on the inlet side of the pump.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 21, 2026
