I dewinterized my class C today. Hooked up to park water. Ran water through all outlets. Did not find any leaks. Disconnected from park water and tried pump. Pump would run but only spit water and air...
Check the connections between the pump in the tank to make sure that none of them are sucking air. I had that happen before after everything sent dry for a while.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 21, 2026
