CMHExplorerAug 19, 2013water pumpwe just got camping in the water pump is not working.I found the water pump it has power to the pump but the pump feels like it is just half pumping. It will not pull water from the tank. Any suggest...Show More
Rolling_CondoExplorer IIAug 19, 2013Make sure the suction line connections are tight. If loose the pump could be sucking air.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
