We have a 2012 crossroads slingshot 27RB. This weekend while camping I turned on the water pump for the first time to locate it for winterizing later this month and when I hit the switch .... Nothin...
IF you are hooked up to city water at the campground the pressure in the lines could be causing the pump switch to think that you do not need the pump. This is how when in dry camp use it knows when to pump.
Release the pressure and is should work.
Dave
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
