We have a 2012 crossroads slingshot 27RB. This weekend while camping I turned on the water pump for the first time to locate it for winterizing later this month and when I hit the switch .... Nothin...
They do not run continuously. They are an 'on demand' pump. Pressure drops they run until pressure is good. There is a pressure switch on pump......good water pressure...no need for pump to run. (Typically run when pressure drops to 30 psi and shut off when pressure reaches 45 psi----or 40/55 if you have a upgraded pump)
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
