Chandalen
May 17, 2015Explorer
(WalMart) sells an adapter for winterization that you hook up an air compressor to. Its like $2.50. If you put a dot of tape on the inside of it, (to close the hole) then put it on the camper and turn pump on, look to see if your problem is fixed. If so, you can A. leave that there, or B. get a new check valve (as mentioned above)
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
