obiwancanoli wrote:
dougrainer wrote:
Only IF the Water Pump is ON AND you have the city Water fill tank valve in the wrong position. There should be no reason to have the Water Pump ON if on City Water. Doug
Duh... thanks.. never occurred to me to consider that... but it makes perfect sense, and so, another lesson learned.
Thanks again!
I should have elaborated further. EVEN if the fill valve is in the correct position(off), if you have the water pump ON and connected to City Water, you will still pull a little water out of the fresh tank when you use the fresh water. Not much, but over time will deplete the fresh tank. If you hear the pump run in this case you are pulling from the fresh tank also. Doug
