schlep1967
Jan 13, 2022Nomad
Deleted previous entry.
Right behind the city water hook-up there should be a check valve. Replacement can be bought for around $10 at home depot.
Make sure you get all of the pieces of the check valve out before you put the new one in. On mine the retaining clip came off the piston. The piston then traveled downstream to the first joint where it go stuck, thus restricting the water flow.
