CA_Traveler
Jan 13, 2022Explorer III
jannie4 wrote:X2 Check valve. Mine was part of the water pump and now replaced.
we always have the plug on the city water intake. In the holding tank we have a screw typle cap with a small hole in the cap which use to have a rubber fitting to keep the cap. should I plug the hole in the holding tank cap.
If the cap hole is to allow air in when using the pump then it can't be plugged. My tank has a vent hose in the top of the tank.
