hhornig's avatar
hhornig
water system not holding pressure
Does anyone know of a plumbing schematic used for fresh water systems? I have a valve which I must open to allow fresh water into the holding tank. When I close the valve I can bring in city water or pump water from the holding tank. Are there any check valves in the system? Currently I have to put a plug in the filling line to get the pump to stop so I think the valve is leaking.
  • Typically 2 check valves in RV plumbing system
    One inside city water inlet....stops water from leaking back out when using ump
    One internal of pump.......stops water from backflowing thru pump when using city water connection
    With a water panel and a valve used to fill fresh water tank via city water connection........valve is all that is used to stop flow thru fill valve to tank.
    So if water is leaking out of city water connection when using pump....that check valve is bad
    If fresh water tank is 'filling' when using city water connection.......fill valve is leaking thru OR pump internal check valve is bad.
    You can install an in-line check valve in pump suction to isolate pump (without rebuilding/replacing pump). Then if tank still is getting water..then fill valve is leaking thru.
    Shurflo in-line check valve
    Here is a basic RV water system.....this one has gravity fill for fresh water tank but idea is the same
  • you need to replace your city water hook up valve
    Yes it has a build in check valve.
    remove the screen and see if it push easy or broken
