Harleyhippie
Nov 19, 2017Explorer
Water tank check valve
Hi all,
I stopped getting hot water and I checked the check valve and it's so corroded I can't get it off.
I sprayed some WD-40 on it but I'm afraid if I apply too much pressure I'm going to break the check valve right off the tank. Wish i could attach a picture of it.
Any suggestions on how I can get it off?
❚ Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
- Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
Thank-you!
Moved from FORUM TECHNICAL SUPPORT
