- mockturtleExplorer IIDo you mean from inside the coach? No. Mine is filled from outside only.
- Do you have a water fill valve that needs to be turned?
- mockturtleExplorer III use one of these Water fill hose attachment but I extend it by inserting a short length of narrower tubing which I super-glued in place.
- GordonThreeExplorergravity fill?
could have an air lock, try using a longer / skinny hose to get farther into the fill port.
less likely, could have an insect nest in the tubing between the fill port and tank. - the_bear_IIExplorerhttps://www.youtube.com/watch?v=NBkVwoiR57A
Air bubble......slow down the water flow to let the air escape.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
