BFL13's avatar
BFL13
Explorer II
Mar 23, 2021
Watt Hrs vs Amp Hrs
This article helps explain these ratings and raises a question wrt battery charging older vs newer LFPs too. Not sure if this also applies to other battery types or if it matters with any when you measure your charging by AH instead of using power. Important--read all the comments too!
It also makes clear why this conversion needs the volts.
https://www.linkedin.com/pulse/amp-hour-ah-watt-hour-wh-how-properly-spec-energy-alkuran-ph-d-#:~:text=(Ah)%20would%20be%20an%20indication,balloon%20force%20that%20water%20out.
https://convert-formula.com/ah-wh
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
