SoundGuy
Apr 24, 2017Explorer
For a 15 amp circuit the International Electrotechnical Commission specifies 15 amps x 125 volts = 1875 watts, for a 20 amp circuit 20 amps x 125 volts = 2500 watts.
From this Wiki webpage NEMA Connectors ...
"The 5-15R is by far the most common electrical receptacle in North America in buildings built since the mid-twentieth century. It is usually installed in a twin duplex configuration (which may be on a common circuit, or alternatively wired with each receptacle on a separate circuit, sometimes switched).
Internationally, the NEMA 5-15P plug and NEMA 5-15R receptacle are the basis for the International Electrotechnical Commission's IEC 60906-2 standard IEC system of plugs and sockets-outlets for household and similar purposes - Part 2: Plugs and socket-outlets 15 A 125 V a.c. and 20 A 125 V a.c."
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
