Just fine. Smart chargers fill the battery to 80% which allows them to start sulfating right off the starting blocks. They end up ruined maybe 3 or 4 months after the warranty ends. Always wanted a SMART charger that turns a 100 amp hour battery into an 80 amp hour battery. You can thank the Socialist State of Californiagrad for outlawing the importation of ANY manual charger. Companies like Harbor Fright REFUSE to ship manual chargers to zip codes in Californiastan. A place where failed lawyers in Sacramento think for you. Even manual chargers with timers to shut off automatically are outright BANNED. Soon, don't laugh, they will be playing the part of doctors and electrical engineers and dieticians. Without a shred of proof they damned near got to the first stage of banning coffee (enforcing the law of putting a cancer warning label on packaging). Instead of insisting on a right out way of thirty feet clearance around power lines, when it's windy they are going to shut the grid down. Remember, you cannot cure STUPID
The MEGAWATT or converters like what BFL 13 likes are the SOLE sources of battery chargers that do not murder batteries in California.
Don Pianotuna, here are the SPECIFICS I have found in repairs to Harbor Freight chargers.
Button diodes that release their bond to cheap aluminum heatsinks. They will then instantly overheat and burn up.
Cheap 19 gauge POWER WIRES inside that attempt to pass 20 amps of current. BRASS fast-on terminals that overheat, then anneal, get soft as butter then the terminal burns up. Selector buttons that burn out, and their function means trying to switch six terminals at once. A DO NOT BUY even at a 90% discount recommendation from me. They are total 100% garbage.
Down here in Mexico, wheeled Schumaker manual chargers are sold in COSTCO for $107 dollars + 8% tax. Mexican batteries are not worth their cost.
Cut out the fan cutout atop a MEGAWATT then place s correct WIRE fan guard using GOOP and this will drastically increase cooling airflow through the unit. Credit where credit is due to LANDYACHT for finding this. For the last year MEGAWATT switched to a higher airflow ball bearing cooling fan that quadruples fan life.
Always use a reliable timer on the AC of a manual battery charger. Unlike a Failed lawyer you can THINK to resolve a problem.
Yeah CALIFORNIA. The home of Ocasio Cortes who wants to ban RV's and air travel. "Take the midnight train to Tashkent and Tokyo?" Because I am a battery engineer I despise the double-digit IQ in Sacramento. Sue me.
Either charge a battery right or spend $500 by destroying them regularly by boondocking with a SMART charger.
