THIS one looks like it will fit the bill.
do you have any plans to maybe add more solar later or change to a bigger panel? I would ge tthe 30 amp version, then you could change your 100 to a 350 or 450watt panel, this will let you bulk charge the main bank and trickel charge the secondary at the same time and they can be different battery types. so you could have LFP for your house and a normal lead acid for the starting.
you can buy a remote monitor for it or just use bluetooth i believe
I looked at that brand but it does not have the remote readout panel. I don't have any plans to add more solar. We never really boondock. I really just need it to maintain batts in storage. And I don't know how long we will keep this RV. As we think more about full timing, I see us buying a larger rig in a year or so.
I did see this setup on Amazon:
- StirCrazyOct 26, 2024Moderator
It does have the remote panel I checked, I think it is a optional add on but it is availble. looks like you got it covered anyways, not to often you'll get a good faith out of a rv company..
I would keep it in the back of your mind that a 100watt panel is pretty much a trickel charger and now your splitting it between two different loads, so you want to make sure you kill any draws when it is in storage, which you probably do.
- way2rollOct 26, 2024Trailblazer
Yeah, I turn off everything, batt disconnect etc. It doesn't get too cold here and the Mercedes chassis battery is beneath the floor pan between the front seats so really challenging to remove each time. That said, the Mercedes does some weird stuff and a lot of electronics so I wouldn't be surprised if there are phantom draws despite the batt disconnect. Still the solar trickle charge would be enough to keep it topped off - if it was working. Thankful to Forest River, hopefully the replacement and new battery will solve the problem.
